Overview
This example is a functional global variable (FGV) within a loop that is called only once. Each time user call the subVI, user can input a enum state in order to start the timer, get the elapsed time.
Description
This example can use as subvi to get the time elapsed.
Requirements
VI Block Diagram
Bonus tip: you can use this vi as a sub vi in a custom error line probe. Makes it super easy to place and remove.
