From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
Example Code
Using the System Exec VI to Launch Applications from the Command Line
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to call a targeted Windows' application (i.e. Calculator) using the System Exec VI.
Description
This VI uses a Call Library Function Node along with string and path manipulation VIs to build inputs to the System Exec VI.  This VI allows the user to make command line calls from LabVIEW.  This example includes the ability to launch Windows Volume Control as well as the Windows Calculator.  It could easily be expanded to include other command line applications.
Note: If you are using a Windows 7 machine, the String Constant in the Volume Ctrl case of the Case Structure should be changed from "System32\sndvol32.exe" to "System32\sndvol.exe"
Requirements
  • LabVIEW 2012 (or compatible)
  1. Select which target application you would like to run using the Target control on the front panel
  2. Click the Run button
  3. Your application will launch
VI Snippet
Solution Prepared By,
Ian Fung, Koo
ian_fung@yahoo.com | Singapore
