Overview
This example VI demonstrates how to create custom error messages in LabVIEW.
Description
In LabVIEW you are able to create custom error codes using native APIs such as the General Error Handler.vi. In this example five custom error codes and relative messages are used to warn the user about possible failures that can happen in different sections of the program.
Requirements
VI Block Diagram
Good example, thanks, I'll probably implement something using this information. The loop though, has no delays, thus it will very quickly do nothing if "Display Error Code" is set to false.
