Overview
This example demonstrates how one can use multiple queues and pass them around the block diagram in clusters.
Description
This application allows the user to enqueue elements to different queues depending on a specific user input using one producer loop and multiple consumer loops. This means we can have many queues dequeing at different rates but all enqueued at the same place on the front panel and with one producer loop
Requirements
Block Diagram
Thank you very much, clear enough.
My only issue is I am no able to create a cluster of queues. I don;t know where to get the queue object from.
A turnaround is using unbundle rather than unbundle by name. But then I aam prone for error with 10 queues stacked.
Thank you for your help ![]()
