Example Code
Using a Single Graph Cursor to Return Values from Multiple Plots in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example VI shows how to make a single cursor that locks onto all plots and displays all the Y values for a single corresponding X value.
Description
The easiest method of doing this is to use the Mixed Signal Graph. If you would like to implement this same functionality on a standard Waveform Graph, you will have to carry out some additional programming. The simple example vi ——Multiplot Cursor (Waveform Graph) .vi to show you how to do this.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run the VI
  2. Move the blue lines in Waveform graph.
VI Snippet
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
Comments
G-Money
NI Employee (retired)
on
Great code! How long did it take you to figure this out?
