Example Code
Using a DAQmx Task Created in MAX in LabVIEW
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This VI is a very simple bit of example code that uses a task created in Measurement & Automation Explorer (MAX) and acquires data.
Description
Tasks in MAX can be used in LabVIEW very simply.  You can either drag a task from MAX straight into your block diagram or you can place a Task Constant from the functions palette. The Task Constant can be found under Measurement I/O»NI-DAQmx. From here all you need to do for an acquisition task is connect the task to a DAQmx Start VI and then to a DAQmx Read VI followed by a DAQmx Stop VI.
Performing a continuous read would require the use of a while loop with a stop condition around the DAQmx Read VI.
There are benefits of using a task from MAX instead of using a DAQ Assistant
  • You can control when the task starts and stops.
  • You can easily use the same channel setup in multiple instances/VIs
  • You can edit some aspects of the task for a particular instance/VI without changing the setup of the task.
  • There are also benefits of using a task from MAX instead of setting up your task completely in LabVIEW
  • You can set up multiple channels, scales, timing and triggers outside of LabVIEW, cleaning up your code.
  • It is easier to port task information between different VIs.
Requirements to Run
Software
  • LabVIEW 8.2 or compatible
  • NI-DAQmx 8.3 or compatible
Hardware
  • Most compatible NI DAQ devices, or simulated devices.
To create a Task in MAX:
  1. Under My System, right click on Data Neighborhood and select “Create new…”
  2. Select “NI DAQmx Task” and press “Next”
  3. Select the measurement type for the task
  4. Select the physical channel(s) to add to the task
  5. Name your task and select Finish
To implement your task in your LabVIEW code:
  1. Select the correct name for your DAQmx task from the “task/channels in” constant of the Start DAQmx Task.vi
  2. Run
Dan King
Comments
搓哥
Member
Member
on
谢谢
BryanEspi
Member
Member
on
What do I have to do to use a task in CANoe? Is that possible?
Contributors
