Example Code
Using Windows DLL
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview:
This example calles Windows DLL's to get the currently logged in user's name. and highlights how to call a DLL from LabVIEW and select the appropriate
LabVIEW datatypes.
Description:
In LabVIEW you can call DLL's by using a Call Library Function Node.  Once you drop the VI onto your block diagram, you need to double click it to configure it to run the above function.
Requirements:
  • LabVIEW 2012 (or compatible)
  1.  Run the vi.
LabVIEW handles strings differently than C/C++, and so special care must be taken when working with strings, otherwise your LabVIEW code WILL crash due to memory management problems.  The following exerpt is from the article: "Using Arrays and String in the Call Library Function Node".
Configuring the Call Library Function Node
Front Panel
VI Snippet
Systems Engineer
SISU
