Example Code
Using UDP To Produce .NET Balloon Popups
Code and Documents
This example builds on top of the brilliant .NET integration VI's for Windows Balloon Popup's found here and integrates it with TCP/IP communication, allowing you to send a command over a Multicast UDP session to a number of remote hosts which will then show a Balloon Popup on the remote system so (for example) sending the command "UPD" could inform a remote client that an update it available for the application.
Comments
AmitKaria2k
Member
Member
on
Can you pls upload "Cleint PC.VI" with all dependencies (VI's and type def's)?
Contributors
