Overview
This example VI Using Queues to Capture Data after Trigger.
Description
This is a small example of how you can use any trigger (a button in this case) to initiate the capture of an incoming signal for a defined period of time. The front panel show on its left the continuously captured input (simulated sine wave in this case). At the bottom you can see the trigger button and a numeric control to set how long you want to capture after a trigger. Lastly the triggered display shows the data that has been captured as a result of a trigger occuring. The block diagram shows how the queue is set up, used in a producer consumer architecture and then released when the program is stopped. See documentation in code for an explanation of how the queue is used.
This example could easily be modified to have a real input signal with associated trigger. The data captured after the trigger could then be viewed as it is in the example or it could be analyzed, saved to a file...
Requirements
VI Snippet
