Overview
This example shows how to use Property Nodes to resize Elements in an Array on the LabVIEW Front Panel.
Description
Front Panel objects in LabVIEW, such as Controls and Indicators, have Properties that can be modified during development. These properties include custom colors or sizes. If a developer wanted to change a Control's Properties while the code is executing, Property Nodes could be used in the Block Diagram. Array Controls or Indicators, however, are a structure that can adapt to any data type. It is possible to change the properties of elements within the array using explicit References and Classes.
This example shows that an Array of any data type has the Properties of the Array Class. An array Property Node can be use to retrieve a Reference to the element. The 'To More Specific Class' VI can be used to change Properties of the Element's class. This example demonstrates this with an Array of Doubles, where each element is a standard Digital Numeric Control.
Requirements
A 3rd Party video tutorial on Property Node basics is found on YouTube. The following link will shortcut to minute 1:51 where the tutorial on property nodes begins.
VI High #2a: Enhance Usability by Disabling and Enabling LabVIEW Front Panel Objects
