Overview
Coding that exemplifies how to use notifiers to pass data to SubVIs.
Description
This code shows the use of Notifiers to pass data to spawned VIs. This can also be used within the same VI. Since Notifiers tends to loose data, this is best used as a way of passing only the most up-to-date information to the consumers.
Requirements
LabVIEW 2012 (or compatible)
Implementation
Producer:
Consumer:
Producer:
Consumer:
