Example Code
Using Index Measurements in VBAI to Recursively Call a Step
Code and Documents
Introduction-
This Vision Builder AI inspection finds five circles on the image with Geometric Matching and then index’s the five matches with the Index Measurements steps. It will then set a coordinate system and run a Find Edges on all five circles based on their indexed geometric matching location.
Steps to Complete-
- Download the two attached files.
- Open IndexInspect.vbai
- Go to the Inspect state and double click on the Simulate Acquisition 1 Step
- Then set the file path to point to the circles.png image that you downloaded.
- Run the inspection and it should look like the below screenshot.
Additional Notes-
You will need VBAI 2011 to run this.
Contributors
