Overview
The following Example shows how to use the Elapsed Time VI to compare the amount of time that a set of data remains above or below a certain thresholding value.
Description
Because this example is using a random number generator as the data, we expect the amount of time below the threshold to follow basic statistical theory. For example, a threshold value of 50 for a range of data from 0 to 100, the amount of time spent below the threshold should be closed around 50%.
Requirements
LabVIEW Base Development System.
1. Select a Threshold value between 0 and the maximum value.
2. Select a maximum value.
3. Run the VI.
This is just what i am looking for but where can i download it, I already tried to rebuild it in labview but it doesn't work as it supose to.
Kind regards
