Overview
This example explains how to use the Counter Digital Debounce Filter for the 660x family. This filter dismisses any input pulse shorter than the duration of a filter pulse.
Description
The code first configures the Counter Task to count Edges. The Counter being used is specified then a property node is used to enable a digital filter. Once the filter is enabled, the minimum pulse width needs to be specified in order to allow for very small signals to be processed while still allowing for a debounce time.
Requirements to Run
Software
Hardware
Block Diagram
Thanks for posting. Please add LabVIEW to your tags and rename your atttachment to include the LabVIEW verison.
