Online shopping is currently unavailable.
Please contact us for help or try again later.
Example Code
Using Control Design & Simulation to create a PID Controller with Generic Plant
Products and Environment
    Software
  • LabVIEW Control Design and Simulation Module
  • LabVIEW
Code and Documents
Description
Overview
The example demonstrates how to simulate a PID control with a simulated SISO model (plant).
Description
The example uses the LabVIEW Control Design & Simulation module to simulate a PID control with a generic Single Input Single Output (SISO) model.
Requirements
 Software
  • LabVIEW 2012 Base Development System (or compatible)
  • LabVIEW 2012 Control Design and Simulation Module (or compatible)
The LabVIEW Control Design and Simulation is now included in LabVIEW Professional, and it is no longer available separately.
 Hardware
  • No hardware is necessary to use this example VI
  1. Setup model settings and PID parameters
  2. Run the VI
Create PID Controller with Generic Plant LV2012 NIVerified.vi - Front Panel.png
Create PID Controller with Generic Plant LV2012 NIVerified.vi - Block Diagram.png
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Matt J - NI Tools Network
Comments
laloceniet
Member
Member
on
thank for this documentary, is great.
tracey66
Member
Member
on
when I loaded the file it failed on deployment and popped up the following error message:
Deploying NILVSim Get Time and IsAcceptedStep.viNILVSim Get Time and IsAcceptedStep.vi loaded with errors on the target and was closed.
LabVIEW:  Failed to load shared library NILVSim.*:SIM_GetTimeAndIsAccepted:C            . Ensure that the library is present on the RT target. Use either MAX to install NI software or FTP to transfer custom libraries to the RT target.
It seemed that I don't have a library NILVSim. Where I can get it?
Thanks.
