Example Code
Using C# to control a LabVIEW VI via ActiveX
Code and Documents
You can use this example to programmatically control LabVIEW and pass data to and from LabVIEW using C#. This is the C# version of the example that demonstrates using Visual Basic to control LabVIEW and was tested with LabVIEW 6.1.
Contributors
