Example Code
User control Access in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
1. Overview:
This VI allows three levels of access: user , engineer and programmer. Each access level will havedifferent access over the elements in the front panel
2. Description:
This VI allows three levels of access: user, engineer and programmer. Users can start and stop the main portion of the VI, but cannot change front panel control values. Engineers can start and stop the main portion of the VI and change front panel control values. Programmers have full access to the VI. For user access level, enter userpwd. For engineer access level, enter engineerpwd. For programmer access level (full access), enter programmerpwd.
Note: You must be logged in as a programmer to access the Logout & Exit button, which is the only way to stop the execution of this VI.
3. Requirements
  • LabVIEW 2012 (or compatible)
4. Steps to Implement or Execute Code
  1. Open "Password Control LabVIEW 2012 NI Verified.llb"
  2. Open ControlAccess.vi
  3. Run the VI
  4. Follow the instructions in the front panel
5. Additional Information or References
VI Front Panel
Justin Parker
Product Support Engineer
