Overview
This example uses the Clipboard LabVIEW Method Node to get the content of the Clipboard, display it on the front panel, and save it as a BMP file.
Description
An event structure in a while loop allows you to monitor the front panel buttons change with minimal CPU usage. The copy button will allow the event that gets the content of the Clipboard and format it as a picture so it can be displayed on the front panel and saved as a picture (BMP here).
Requirements
- LabVIEW 2013 (or compatible)
- Choose the path to the BMP file you want to read.
- Save a picture to your clipboard (you can use the print screen key). then click on the "Copy" button.
- Repeat this operation as many times as you need.
Additional Information or References VI Block Diagram
VI Snippet
