Overview
To demonstrate how to utilize cursors in a graph for manipulating data
Description:
This VI was created in order to allow a user to use the cursors of a Graph Indicator to manipulate a set of data. This uses a DAQmx task to gather a finite number of sample data. The user then can select the cursor position to find the average of the data.
Steps to implement or execute code
To implement this example:
- Set parameters for configuration settings.
- Run VI!
- Click Do Test? button.
- Change cursor positions for the start and stop
- Once select, hit "Do Test?" button again to gather data and find the Mean
- Modify VI as needed to use the cursors for data manipulation
To execute this example:
- Install the required software.
- Connect the DAQ hardware that supports the Analog Input features
- Confirm the connection with the MAX with TestPanel
- Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series Analog Input Module
Frank,
Software Group Manager
