Contactless Test Station III (CTSIII) is able to emulate Near Field Communication (NFC) reader and communicate with a device acting as an NFC listening device such as:
- banking smartcard
- transportation ticket
- NFC enabled smartwatch
- NFC enabled smartphone
CTSIII supports common NFC communication protocols such as:
- ISO 144443 type A or B at all data rates
- Felica at 212 and 424 kbits/s
- ISO 15693 (Vicinity) all data rates and all modes
- Mifare Classic / Ultralight / Ultralight C
End-user may want to build test scenarios and analyze the communication between CTSIII and a device acting as a card for several reasons:
- build simple communication script and analyze device under test answers
- for debugging purposes
- build a script and test it within MPManager before implementing a test application to do the same or more thanks to MPuLib communication dll and libraries
- perform specific measurements or tests and compare the results with ISO, EMVCo or NFC Forum test specifications.
In this example, a very simple exchange between the CTSIII and a Type A banking card will occur.
In addition, an acquisition of the exchange will be performed by the NFC board of the CTSIII.
The acquisition will be performed at a sampling rate of 150 MHz.
The measured samples will be added to the *.mplog trace and accessible in MPManager viewer for review.
Description-Separate-2
CTSIII is delivered with an NFC simulation antenna (P/N 786703-01).
The antenna is used to perform continuous and successive exchanges with an NFC device, using either MPManager scripting and test functions or a user program.
Perform the following connections between the antenna and CTSIII:
| Antenna connector | CTS3 connector |
| TCL3 HDMI | AUX 1 HDMI |
| Analog In SMA | ANALOG IN SMA, using the provided SMA low-pass filter (P/N 773919-01) if configured in 50 Ω |
| Tx/Rx SMA | TX/RX SMA |
Download the Burst_Analog_Measurement_TypeA script and video in the attachment.
Power on CTSIII and open MPManager 3.9.0 (or above).
Position a Type A banking card on top of the PICC-PCD simulation antenna.
Connect the CTSIII and like in the video, open the Burst_Analog_Measurement_TypeA script in the script editor of MPManager UI
and execute the script.
End-user has access to the execution log of the script where the answers from the card can be seen.
In the viewer tab of MPManager, the end-user gets access to the *.mplog trace, including the analog capture and can navigate through it to analyze the communication
between the CTSIII and the card under test.
Before starting an analog capture with the NFC board of the CTSIII it is important to:
- select the reception channel: Analog In
- adjust Analog In impedance: 50 Ohms
- select the appropriate trigger: TRIGGER_ANALOG
- select the appropriate event to trigger on
- configure the capture
to include the measured sample within the *.mpolg trace
to adjust the source
to set the duration of the acquisition
to set a delay with the event previously selected to start the acquisition
Then, the end-user script has to contain
- start spy to start building the *.mplog trace
- the exchange to be captured
- and a stop spy at the end
How-Separate-2
For any additional questions, please contact NI technical support team on NI.com when opening a Service Request case using the NI Service Request Manager (SRM).
To open a service request on NI.com please follow the steps described at this link.
https://micropross.ni.com/webinars/contactless-test-station-3-external-webinar/
Related-Separate-2
