This example uses Microsoft Outlook ActiveX objects to create a new message and then send that message using the Microsoft Outlook engine. The VI was developed and testing using Microsoft Outlook 2002.
Note: This example has been tested with LabVIEW 2021 and Outlook 365 with no issues.
I'm facing a problem using the SubVI send_outlook_mail_active.vi. The problem is that I get the below broken wire error if I use the SubVI in a project that also includes cRIO. It worked and still works fine if I use it in a VI with simulated modules. However I would like to use it with cRIO, the idea is that it will send me an email if the values I'm measuring are not not within the limits.
I wander if anyone has faced a similar problem or knows how I could resolve my problem? I have never used the blocks used in the SubVI, so I'm bit lost.
Additional information about my systems
- LabView 2021 - 32 bit
- LabVIEW FPGA Module 2021
- LabVIEW Real-Time Module 2021
- NI CompactRIO Drivers 21.0
- NI DAQmx 21.0
- cRIO-9056
Thank you in advance!
Kind regards,
Hossein Bakhtiari
This is great. Happy to report it still works in 2024!
Any idea why the Outlook_.MailItem doesn't have a 'Message-ID' element?
Is there a way to set the 'Message-ID' using this Outlook class?
Hello, this example code worked for me. I am using LabVIEW 2020 and my company uses Microsoft® Outlook® for Microsoft 365 MSO (Version 2502) 32-bit.
