Overview
Code that allows us to change the status of a control using the "End" key.
Description
This VI uses a Property Node called "FocusKeyBind" to map a keyboard stroke to a control on the Front Panel.
The VI then polls for this keystroke and updates the value of the Stop control when the 'End' key is pressed.
Requirements
LabVIEW 2012 or compatible
1. Run the VI
2. Press the End key on your keyboard
