Example Code
Use Keyboard Hotkeys to Control Master System Volume using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example code first listens for button presses on the keyboard. If the correct key is pressed, the program executes a Windows API call through user32.dll to increase, decrease, or mute the volume.
Description
  1. Run the VolumeMaster.vi
  2. Press F10 to lower the volume, F11 to mute, and F12 to increase the volume.
Requirements
Software:
LabVIEW 2012(or compatible)
  1. Download the .zip file
  2. Set your desired configuration (a, x1, x2, degrees, etc)
  3. Run the VI
VI Block Diagram
