Overview
This example VI show a way to use Filter Events to discard key presses for any key except Return.
Description
If you have key focus on a Boolean control on the front panel, you can use the following keys to toggle the Boolean state:
1)Return or Enter
2)Space
3)T/F
4)1/0
5)+/-
There is no way to disable these standard keyboard actions, so if the UI requires that only the Return key can toggle a Boolean control, you must find a workaround. This example shows how you can use Filter Events to discard key presses for any key except Return.
Requirements
VI Block Diagram
