아래의 제품을 비롯한 NI 소프트웨어를 다운로드하시려면 ni.com/downloads를 방문하십시오.
Overview
This example uses a counter input to trigger a serial acquisition. When the counter detects a digital event, the specified string command is written to the serial port and a serial read is executed.
Description
Serial commands are typically software-timed, sent every iteration of a loop. By importing a sample clock, the serial commands can be synchronized with external acquisitions based on hardware timing. Each time the external sample clock strikes, an event is registered and each event triggers a serial acquisition.
Requirements
Software
Hardware
Block Diagram
NI 커뮤니티에 있는 예제 코드 교환의 예제 코드는 MIT 라이센스로 라이센스가 부여됩니다.
Great stuff!
