Overview
This VI demonstrates how to see changes in an array while the VI is running.
Description
This VI compares two methods of accumulating 2D Boolean arrays.
The non-updating array simply receives a true constant wired out of two auto-indexed For Loops. While this may be the easiest way to accumulate our 2D array, we cannot see the LEDs in the array update during run-time since the indicator can only update once both loops have finished executing.
The updating array uses Insert Into Array blocks and shift registers to accumulate an array that can be updated inside the inner-most loop. Using this method, any changes made to the array can be seen during run-time.
Note: The auto-indexing wires which are fed into the For Loops only exist in order to force the loop count to be the exact size of the array. They are not used to pass data into the array.
Requirements
VI Snippet of Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
