Overview
This example is a Microsoft Visual Studio solution contains an updated version of the example that ships with Measurement Studio 2013 for Visual Studio 2012.
Description
The shipping example for the WiX installer includes a number of different libraries that are used in Measurement Studio 2013. This is in the file Product.wxs.
This new example provides a template for the NI Driver Merge Modules. By default, these are commented out. Please note these are just the merge modules, not the drivers. In order to use hardware, one must install the runtime version of the desired drivers or the full versions of the drivers to the target machine.
Also note if one is building an installer for a .NET 4.5 applications, one may need to install the .NET 4.5 runtime framework to the target machine. This installer for will make a file called Setup.msi. Upon running the MSI, your .NET application will be installed just like any other Windows application. As a final note, this example is only for Visual Studio 2012.
Requirements
**This document has been updated to meet the current required format for the NI Code Exchange. **
This is an amazing example. Thanks for posting this.
Hi!
I got the sample prgoram to install fine with all DLLs to local directory instead of GAC. However,
there seems to be a problem with uninstalling? After uninstalling, there are 22 National Instrument files left in the install directory (C:\Program Files (x86)\Example Company Name\Example Application):
NationalInstruments.Common.config
NationalInstruments.Common.dll
NationalInstruments.Common.Native.config
NationalInstruments.Common.Native.dll
NationalInstruments.MStudioCLM.config
NationalInstruments.MStudioCLM.dll
NationalInstruments.NiLmClientDLL.config
NationalInstruments.NiLmClientDLL.dll
policy.12.0.NationalInstruments.Common.dll
policy.12.0.NationalInstruments.Common.Native.dll
policy.12.0.NationalInstruments.MStudioCLM.dll
policy.12.0.NationalInstruments.NiLmClientDLL.dll
policy.13.0.NationalInstruments.Common.dll
policy.13.0.NationalInstruments.Common.Native.dll
policy.13.0.NationalInstruments.MStudioCLM.dll
policy.13.0.NationalInstruments.NiLmClientDLL.dll
policy.9.0.NationalInstruments.Common.dll
policy.9.0.NationalInstruments.Common.Native.dll
policy.9.0.NationalInstruments.NiLmClientDLL.dll
policy.9.1.NationalInstruments.Common.dll
policy.9.1.NationalInstruments.Common.Native.dll
policy.9.1.NationalInstruments.NiLmClientDLL.dll
Any suggestions?
And one more thing: If I try to do a passive install:
msiexec /i Setup.msi /passive
I end up with all the NI stuff in
C:\Program Files (x86)\Example Company Name\Example Application\Module Retargetable Folder
It works fine if I don't add /passive??
It also seems to work if I explicitly set the installdir on the command line:
msiexec /i Setup.msi /passive INSTALLDIR="C:\Program Files (x86)\Example Company Name\Example Application"
Hey NielsUII, could you post this to the forum? To be honest, I am not sure why we are seeing this behavior and it would be better to post to the forum to get a little more visibily on the issue at hand.
Edit: Please post the link here to the post you create so we have a reference to it.
I have posted the question here: http://forums.ni.com/t5/Measurement-Studio-for-NET/Problems-with-wix-merge-modules-when-not-copying-...
