Example Code
Update XY Graph With Multiple Plots In Real Time Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to add multiple plots of data to an XY graph as the data points are acquired in real time.
Description
The example uses the cluster data type for the XY graph. Each cluster data including an x-axis value and a y-axis value is concatenated to build an array. This process is repeated until the iteration number is reached to "Number of Plots". The default control values run a simulated acquisition with 4 separate tasks. Each task acquires 3 separate samples and then moves on to the next task.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Configure "Number of Plots" and "Number of Simulated Data Points"
  2. Run VI
VI Block Diagram
Ian K.
Software Developer
Data Ahead AG
