Example Code
USB RAW Bulk Communication with Visual C#.NET
Code and Documents
This application illustrates simple reads and writes as results of user events to a USB RAW device. It is designed to work with USB RAW devices only.
To run this application, install a USB RAW device and configure Measurement & Automation Explorer (MAX) to recognize the USB device (see Tutorial: Using NI-VISA 3.0 to Control Your USB Device at www.ni.com). After the USB RAW device is successfully installed and configured, and you have opened a session to the device, you can read to and write from the USB RAW device.
To read to or write from another USB device, close the session to the current device, select the other device from the VISA resource name control, and open a session to it.
When finished, simply close the window to exit the application.
Contributors
