Example Code
Two-Signal Edge-Separation with Different Sources
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This code allows the user to change the source signal for a Two-Signal Edge-Seperation measurement from the internal clock, to a different signal.
Description:
This code was developed for use in detecting a signal (called the 'Source' signal) that arrives after a start signal, but before a second.  In this case, the second signal was derived from the first by delaying it with a length of wire to around 200ns.  With the start and stop signals configured, a third signal was to be detected.  A time measurement wasn't of critical importance, just rising edges of the source signal.
This code was created using the Two-Signal Edge-Separation example code included with LabVIEW 2012.  It has been simplified and stripped down to only include Two-Signal Edge-Separation.
Steps to Implement or Execute Code:
To implement this example:
  1. Define the counter, the new source of the signal and the start and stop edges
  2. Wire the DAQ based on the wiring configuration of Two-Signal Edge-Separation
  3. Run the VI
  4. (Optional) Turn on the Highlight Execution to see the flow of the VI
To execute this example:
  1. Install the required software.
  2. Connect the DAQ hardware that supports the Counter features
  3. Confirm the connection with the MAX with TestPanel
  4. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 9.0 or compatible
Hardware
cDAQ with C series Counter Input Module
undefined
undefined
Bobby Breyer
