Example Code
Two Boolean Buttons One Active at the Time
Code and Documents
Overview:
This VI shows how to toggle between buttons.
Description:
This example uses property nodes to disable and enable buttons depending if one or the other are pressed.
Requirements:
LabVIEW Base Development System 2012 (or compatible)
Steps to Implement or Execute Code:
1. Run the VI
2. Alternate pressing the buttons
3. Press stop when done
Additional Information or References:
