Example Code
Triggering Analog Voltage Output with Analog Input Voltage Window Using LabVIEW with DAQmx
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This code shows how to trigger an analog voltage output with an analog voltage input range.
Description
This function is accomplished by using two simultaneous while loops each running a continuous DAQmx task. The top loop is the input task and when the input value falls within a range it uses a case structure to set the "Voltage output" local variable. The bottom loop is the output task and it is continuously outputting a voltage which can be set by the front panel or by the logic in the input loop.
Requirements
  • LabVIEW 2012 (or compatible)
  • DAQmx 9.5.5 (or compatible)
  1. Select the physical channels and set proper parameters.
  2. Run the VI.
VI Snippet
Ben Sisney
FlexRIO V&V Engineer
