Example Code
Triggered Digital Input and Output Running at Different Rates
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This VI starts a hardware timed digital output and input task running at different rates using a dummy analog input task.
Description:
This examples was developed for an M series device, two counters are used to generate the sample clocks for the I/O tasks.
Steps to implement or execute code
To implement this example:
  1. Configure the front panel.
  2. Run the VI
To execute this example:
  1. Install the required software.
  2. Connect the DAQ hardware
  3. Confirm the connection with the MAX with TestPanel
  4. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series or compatible DAQ devices
Sean Ferguson
Application Engineering Specialist | RF and Reconfigurable Test
