Overview
This example uses dynamic event registration to trigger an event for changing the index display of an array control.
Description
The value of the index display of an array control or indicator is available using a property node. However, property nodes use VI server and cannot be used to trigger an event in an event structure.
Requirements
1.Update the value of the Event Data control
Labview front panel
For those that find this I accomplised the same result without polling. Use a mouse down event on your array control. Then take the mouse coordinates and compare them to the IndexRect to see if it was in the index.
