1. Overview
This example VI uses the Thomas algorithm for Gaussian elimination of a tridiagonal matrix. It outputs a solution vector from one input known vector.
2. Description
A tridiagonal matrix is a band matrix that has nonzero elements only on the main diagonal, the first diagonal below this, and the first diagonal above the main diagonal. In numerical linear algebra, the tridiagonal matrix algorithm, also known as the Thomas algorithm (named after Llewellyn Thomas), is a simplified form of Gaussian elimination that can be used to solve tridiagonal systems of equations.
Tridiagonal matrices are important in the numerical solution of partial differential equations. Rather than using a general linear solver, a specialized algorithm can be implemented for improved performance.
3. Requirements
4. Steps to Implement or Execute Code
5. Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines.**
