Overview
The example is to demonstrate the flow of generating a triangular signal and then acquiring it with the analog output and record it with a measurement file.
Description:
The VI would independently generate
Steps to Implement or Execute Code:
To implement this example:
- Define the Physical Channels and source for the trigger
- Set the value of the parameters as needed
- Run the VI
- (Optional) Turn on the Highlight Execution to see the flow of the VI
To execute this example:
- Install the required software.
- Connect the DAQ hardware that supports the CO features
- Confirm the connection with the MAX with TestPanel
- Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 9.0 or compatible
Hardware
cDAQ with C series Counter Output Module
