Example Code
Transmit Waveform through CAN Objects using PCI-CAN cards
Code and Documents
This VI is based off the "CAN Object controls RTSI on Waveform Transmit.vi" example from the LabVIEW Example Finder. The modification was made for PCI-CAN cards that do not have a RTSI output but still want to submit custom CAN frames without duplicating the data output using CAN Objects.
Directions:
1. Open VI
2. Select CAN Interface and run VI.
The VI is uploaded in LabVIEW 2011 and LabVIEW 8.6
Contributors
