Overview
The example shows how to calibirate five thermocouples.The calibration process has to be done by LabView Application.
Description
My Application has to perform the following tasks in sequence
Step 1: User has to read current calibrator parameters via RS232 and it has to be displayed
Step 2: User can change the parameter values serialy
Step 3: Reference temperatures for calibiration should be control
Step 4: After all the necessary parameters has been set user has to start the calibration
Step 5: If any necessary parameter has not been set, Then a error message has to popped up and he has to repeat the Step 1 & 2
Step 6: Start Calibiration
Step 7: Bath has to be set for all reference temperature and the stailized Thermocouple reading from ni 9213 for the known temperature has to be logged in .csv file.
Step 8: User should have a control to stop Calibiration in Middle.
Requirements
Software:
- LabVIEW 2012
- Unzip the attached folder to your computer
- Open the VI "Calibrator 2012 NIVerified.vi"
- Run the program
VI Snippet
