Overview:
Demonstrates on acquiring thermistor measurement with NI-9219.
Description:
Since the NI-9219 is a viable option for thermistor readings but does not support thermistor tasks, this code shows one way to get the thermistor measurements using the NI-9219. This VI utilizes a resistance task to acquire data from the 2-wire thermistor using internal excitation.
Then, it converts the resistances to a voltage by multiplying the values by the excitation current, to ensure the correct values are passed into Convert Thermistor Reading.vi.
Requirements:
Instructions:
Block Diagram Steps:
