Example Code
TestStand Data Access Library
Products and Environment
    Programming Language
  • LabVIEW G
    Other
  • TestStand
Code and Documents
Description
This library extends the data access functions for accessing TestStand data from LabVIEW.
APIs
The library contains the following APIs,
  • TS.ReadData
  • TS.WriteData
  • TS.CheckVariableExist
  • TS.DeleteData
  • TS.CastDataName
  • Advanced
    • TSPropObj.ReadData
    • TSPropObj.WriteData
    • TSPropObj.CheckVariableExist
    • TSPropObj.DeleteData
    • TS.GetEnvironment
    • TS.ConfigureEnvironment
    • TS.SetFlag
    • TS.ResetFlag
Supported Data Type
LvData Element 1DArray 2DArray 3DArray Comments
Number √ √ √ √ LvData - I8, I16, I32, I64, U8, U16, U32, U64, SGL, DBL, EXT
TsData - DBL
Enum √ x x x LvData - Enum U8, Enum U16, Enum U32, Enum U64
TsData - DBL
Boolean √ √ √ √
String √ √ √ √
Timestamp √ √ √ √ LvData - LabVIEW Timestamp - ni.com
TsData - DBL
Waveform √ √ x x LvData - LabVIEW Waveform (DBL) { t0, dt, Y, attributes }
TsData - Container { t0, dt, Y }
Cluster √ √ x x
Software Environment
  • LabVIEW 2019 or newer version
  • TestStand 2019 or newer version
Dependencies
  • OpenG Toolkit
How to Use
In order to use this library,
  1. Open VI Package Manager, browse and install OpenG Toolkit
  2. Download and install the *.vip from the attachments section
  3. The library APIs are located in Functions Palette >> Addons >> TestStand Data Access
Contributors
