Description:
This VI highlights the inefficiency of USB 2.0 on Windows and therefore highlight the new advantages of USB 3.0, when available. Note the CPU usage of the two modes (via task manager) ; the VI needs to be restarted for the new mode to take effect.
To save CPU with USB 2.0, in a low frame rate/long term monitoring application, it is more efficient for the acquisition to stop and start when images are needed rather than letting the acquisition run in the background while discarding excessive images.
This VI uses LabVIEW 2012 SP1 and Vision Acquisition Software (IMAQdx 4.0), and therefore can be used with any IMAQdx supported camera (GigE, IEEE 1394, USB 3.0) also.
Instructions:
Is there any possibility to search via labview if connected USB camera is 2.0 or 3.0 type?
There may be a way to do so, but I am not sure. I recommend creating a new discussion forum post or NI support ticket if you would like assistance researching this question.
Best of luck!
