Example Code
Temperature Monitor using LabVIEW
Code and Documents
Overview
This LabVIEW project shows how to implement a temperature monitoring in Labview.
Description
This project is composed by 1 MainVI and three SubVIs. The MainVI implement the temperature monitor while three SubVIs implement respectivily:
  1. Simulate temperature
  2. Celsius to Fahrenheit conversion
  3. Implement the simulated thermometer
The simulated temperature is monitored and charted. If the temperature goes above the "High Limit" that you set the boolean indicator turns on.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Unzip the attached folder to your computer
  2. Open "Temperature Monitor.lvproj"
  3. Open the VI "Temperature limit Main"
  4. Set parameters
  5. Run the program
Main VI Block Diagram
Justin Parker
Product Support Engineer
