Example Code
Task Manager
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This is a simple VI that aims to illustrate the abilities of the system exec function
Description
In this example, pulling list shows the currently executing process, click and choose from one of these processes and terminate it.
CMD task list command to get a full list of the processes which is displayed  on a front panel indicator.
The program wait for an event to exit or to kill a process using the CMD Task Kill function.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run VI.
VI Block Diagram
Aaron. E
Product Performance Engineer
Dyson
Comments
Alex.T
Active Participant
Active Participant
on
Sup Aaron! That's a pretty cool example. In the Event Structure it might be worth using a Case Structure to check whether someone's hit the Stop Process button with the 'Select Process' option in the Combo Box still enabled. This would prevent any false commands generated.
Alex Thomas, University of Manchester School of EEE LabVIEW Ambassador (CLAD)
terickson
Member
Member
on
I think you have to put quotes (") around the name of the application you are terminating if if contains spaces.  At least on Windows XP.
CLA
