Overview
This example demonstrates one method of creating a table that appears to mix both input and output.
Description
The table shown on the front panel is an array of clusters. The cluster is an input control, but two elements are disabled from the properties menu. Data from the block diagram, or in this case, a separate control, can be displayed to these columns, and the use is still able to enter data into the remaining columns for use on the block diagram.
Requirements
VI Block Diagram
