Overview
This example demonstrates how to use a Tab Control to execute different portions of code based on which tab is selected.
Description
The Tab Control has similar functionality to an Enum on the block diagram. In this example, there are four tabs. The Tab Control is wired into the Case Selector terminal of a Case Structure, and the selected Tab is the case that executes.
Requirements
LabVIEW 2012 (or compatible)
Click on the Run arrow
Click on the different Tabs, which are labeled "Page 1", "Page 2", "Page 3", and "Page 4"
Different Cases Block Diagram
Front Panel
As any CLADer knows, polling a control is resource intensive and poor practice. Can an event structure be used to fulfill the same purpose?
