This example will teach you how to use TDMS functions to log DAQmx data from one channel while storing the data in a separate column.
Description-Separate-2TDMS writes separate columns as channels. In order for each loop to store the data in a separate column, you need to set the loop as the channel by either
How-Separate-2
Note: These TDMS channels do not refer to the same channels on the hardware in which you are acquiring data.
Additional-Separate-2Related-Separate-2
