Overview
This VI takes a TDMS file with multiple data points and writes this data to multiple TDMS files.
Description
It sorts the TDMS file into smaller ones by looking at the time stamp between data points. If the timestamp between data points is greater than the user specified tolerance, the program will consider the new data point to be the start of a separate log and end up placing it into a new TDMS file.
Requirements
Front Panel
VI Snippet of Block Diagram
Is there an example that is doing the opposite, merging smaller TDMS files into a bigger one?
