Example Code
TDMS File Playback With the LabVIEW Control Design and Simulation Module
Code and Documents
Description:
This example demonstrates how you can read in a TDMS file in LabVIEW and then use the values contained in the TDMS file as part of the Control & Simulation Loop.
Version Information:
Host PC:
  • LabVIEW 2011 SP1
  • LabVIEW Control Design and Simulation Module 2011
Instructions for Running:
1. Make sure to specify the correct path to the TDMS file before running the VI
2. Run the CD&SimTDMSPlayback.vi
Front Panel:
Block Diagram:
Tim A.
Contributors
