The built-in TCP/IP functions in LabVIEW are handshaked operations, such that you should not lose packets of data during a continuous TCP send operation. TCP handshaking is done by the operating system. At the end of a communication stream, such as when the server or client application is halted or the communication link is interrupted, it is possible for the operating system to acknowledge the receipt of a packet that the reader has not yet read into LabVIEW.
This example provides an easy way to implement a writer aware of whether the packet was received by the LabVIEW reader or not, even in abnormal end-of-stream conditions.
These VIs are drop-in replacements for the built-in LabVIEW functions TCP Read and TCP Write. They implement application-level handshaking such that data will never be reported received (no error) without being received. Furthermore, you are guaranteed that if a packet is reported received, the data was not only received, but it was exactly the same data that was originally sent. This is important when data integrity is essential. However, due to the added functionality, this VI cannot achieve the same data transfer rates that the built-in TCP functions offer.
LabVIEW NXG 1.0 or compatible
1. Open one of the TCP examples that ships with LabVIEW as a starting example.
2. Use these VI as a drop in replacement for "TCP Read.gvi" and "TCP Write.gvi" when you need application-level handshaking such that data will never be reported received (no error) without being received.
Note: The built-in LabVIEW function "TCP Open Connection.gvi" or "TCP Listen.gvi" should still be used before these functions to open the TCP connection, and the "TCP Close Connection.gvi" should still be used after these VIs to close the TCP connection.
