Overview
Code for TCP/IP over SSL
Description
LabVIEW doesn't provide any support for SSL based TCP/IP communication unlike HTTP. Hence, for one of my project, I have developed a small library that fulfills the role of a TCP SSL server.
It works fine for me but I am still improving on it for implementing the asynchronous methods.
If anyone has any idea, feel free to suggest.
Requirements
Software-LabVIEW.
Hardware-Tested on Win7-32 bit OS.
Additional Images or Video
This seems to only support the server side (as stated). How difficult would it be for a client side.
Kas
Hi Kas,
I am working on it. Will update soon.
Runjhun.
Thanks for posting your code! I also need an SSL client, so I'm working from your server code as an example. If you have a client in the works, I'd be interested in seeing it.
Nathaniel
I am running SSL server from example folder, but it throws following error message.
How to resolve this certificate issue?
I need an SSL Cleint ,If you have it ,please update
I have been getting many requests for posting the SSL client code.
The implementation of the SSL client is bit tricky in LabVIEW. When I was designing it to work for my server code, LabVIEW was hanging more than often. Also I needed asynchronous communication and which cannot be supported by only LabVIEW .net calls.
So I ended up writing a C# code that implemented the SSL client functionality. I used that DLL and registered the connect/authenticate/read/write events using event callbacks functionality in LabVIEW.
Unfortunately the DLL code is proprietary so I cannot share that. Though if anyone is interested I can let you know the high level .net functions I have used to implement that. But definitely you need an additional programmer to write that code for you.
I'm trying to create an server application using the library that you shared. Unfortunately I'm not able to pass the SSL server authentication irrespective of trying with various server certificate files and SSL protocol types. I repeatedly get the below error. I hope you would have faced the similar issue during implementation phase and help me out in this.
Error 1172 occurred at Invoke Node System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation.
Inner Exception: System.Security.Authentication.AuthenticationException: A call to SSPI failed, see inner exception.
Inner Exception: System.ComponentModel.Win32Exception: The client and server cannot communicate, because they do not possess a common algorithm
Possible reason(s):
LabVIEW: A .NET exception occurred in an external assembly. For information about correcting this error, copy the following exception (in bold), and search the Microsoft Developer Network (MSDN) Web site or the Web for a possible explanation.
System.ComponentModel.Win32Exception in SSL Lib.lvlib:Authenticate SSL Server.vi:2210001->Sever SSL.vi
The TLS/SSL functionality in Labview now appears to be in Beta: (Labview 2020?)
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/SSL-TLS-Support/idi-p/3314187
